Author Topic: Steering wheel repair  (Read 4486 times)
« on: March 14, 2004, 20:42:44 »
I've got a 65 230sl, it is my baby. The steering wheel is looking cracked and worn. Is it possible to repair the steering wheel, or just cheaper to find one and buy it. I've got the time, but is it worth the time and effort.
Michael
  • USA, VA, Alexandria
Re: Steering wheel repair
« Reply #1 on: March 14, 2004, 21:33:01 »
There are companies that can take a steering wheel with cracks and repair them so they look like new.  They use epoxy filler.  I have never used this service.  Here is a sample company:
http://www.dealsonwheels.com/parts/garys/
www.Eastwoodco.com sells a restoration kit:
http://www.eastwoodco.com/itemdy00.asp?T1=52061&I1.x=45&I1.y=57
Hope this helps.
____________________________________
1971 280sl Tobacco Brown
1994 E320 Cabriolet, Smoke Silver
1999 E320 Wagon 4 matic, Brilliant Silver
« Last Edit: March 14, 2004, 21:35:01 by Tom »
ted280sl
  • USA, NY, New Rochelle
« Reply #2 on: March 15, 2004, 18:05:49 »
Michael,
  I bought the restoration kit from Eastwood. It includes a detailed instruction book and some epoxy. You can buy the epoxy from any store for about $10 and do it yourself. If you fill the cracks with the epoxy and wet sand it until the entire wheel is really smooth it can be painted. I have been having some trouble with the painting part but, it can be done. If you don't like it you can always buy a steering wheel.
Good luck,
Ted
« Reply #3 on: March 15, 2004, 18:33:05 »
MB still has new ones. Black $218.00, white $172.00
tom in CA
tom in CA
113gray
« Reply #4 on: March 17, 2004, 08:50:43 »
Yes, you can redo a steering wheel via the Eastwood approach etc. I hvae done this (non MB wheel) & am able to report: 1) This is a helluva lot of work to do right, so be prepared! 2) My job looked perfect on finishing; I sold the vehicle 2-3 years later & tiny, almost microscopic cracks were appearing over the old areas of repair, which makes sense if you consider repairs with filler & paint are not likely to hold up as well as a new wheel. I also replaced an ivory MB wheel w/ new & it still looks new 3 years later. Faced w/ this situation again, I would go with a new wheel - unless I wanted to do it on the cheap. FWIW      -JP-
