Author Topic: Trash or Treasure? Label  (Read 3771 times)
Jim Donati
« on: May 04, 2010, 04:03:21 »
I recently stumbled upon this label in the interior cabin of my 1970 280SL. As I touched it, it fell off in my hand.
It was located inside the car mid-way up the bottom of the steering wheel column (between my knees as I sat in the drivers seat).
Does anyone have any idea if this label might have been something that was applied at the factory during manufacture?  Possible an inspector's mark?
If my goal is to keep my 280SL as original as possible, should I trash it, or reapply it?
Jim
« Last Edit: May 10, 2010, 23:54:39 by 280SL71 »
Ulf
Re: Trash or Treasure?
« Reply #1 on: May 04, 2010, 07:44:53 »
Have no idea, but it looks like a label for a spare part - I'd stick it back on with a little glue...
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
« Reply #2 on: May 10, 2010, 16:51:01 »
Jim,
Wow, never seen before. :o
It's definitely not a spare part tag.
I'd keep it if I were you. But I don't know where it belongs.
You said it was located anywhere on the steering column? Can you find old remaining glue marks  on the column? Are your under-dash cardboards still in place?
No idea ...
Jim Donati
« Reply #3 on: May 10, 2010, 17:00:27 »
I can easily identify where if fell off from the glue marks and because I saw it hanging by a corner before it fell off.  I will replace as everyone suggests.
I believe all my under dash cardboards are still in place.
Jim
