'I am putting the car back together after changing the clutch and repairing the transmission. The 2 small linkages are both bent. The driver side if you hild the transmission end on a bench the shifter end will be 1-3/4 inches above the bench. The other one bends up about 1-1/2 am I learned from tomHanson the inkasge was different for the first 1400 serial numbners and is no longer available, Shuold I ise the bent roofs?, SHiuld I try to malke larter model linkGAGES work or should .ty to bend these straight
