Author Topic: Start and "Stutter"  (Read 4236 times)
KevinC
Start and "Stutter"
« on: May 27, 2010, 02:48:32 »
Each time I start my 230SL, it runs roughly for about 10 seconds (almost like on five cylinders instead of six) but then evens out. Also, stopped at a light with my foot on the brake, it idles okay but tends to "stutter" or stumble every few seconds? Any idea on how to diagnose and remedy?
Re: Start and "Stutter"
« Reply #1 on: May 27, 2010, 04:26:26 »
Kevin, are you still using points? If so, I'd take a peak at the dwell reading. Shoot for around 38-40. Plugs too if its been awhile? Be sure timing is on target. At least that is what I'd do. Good luck.
jacovdw
« Reply #2 on: May 27, 2010, 09:33:27 »
Kevin,
You mention that the stutter is there when you start the car. Does it happen during both cold and hot starts or just cold starts?
Assuming that the basics on your car is sorted as James has mentioned (correct valve clearances, correct dwell and ignition timing, correct spark plugs and gap, correct air/fuel mixture), we can then look further.
If it happens during a cold start, then it basically means that the fuel injection lines are not holding residual pressure. That means that pressure has to build up in the affected lines for a few seconds before the engine smooths out - hence the stutter.
A simple way to test if the injectors are the culprits, is to have them tested for opening pressure and spray pattern. Most shops that specialize in Bosch diesel injection pumps should be able to do that for you.
A dribbling injector will give you poor performance and not hold pressure in the lines. If the injectors are fine, then you need to consider the check valves in the fuel injection pump itself.
I had a similar problem with my 230SL and solved the problem by replacing all 6 injectors. Two of the original R1 injectors were dribbling badly and only the R2 injectors are available now from Bosch.
Good luck and keep us posted.
