Hi All,
Right im done!
The parts you need I have listed above. Thanks again Ed and Mark.. you have been invaluable!
A good selection of nuts, bolts and washers is also needed.
So the process to convert from 4 to 5 speed manual is as follows (from memory):
- Cut off the two upper rear mounts on Getrag Gearbox (Pictures of this are on Marks thread) and smooth off
- Cut off the sleeve around Input Shaft on Getrag
- Slide over Marks Input Shaft Spacer with a bit of Loctite, or if tight already then just tap on after heating up with chamfered end facing into engine
- Install the two L shaped brackets on the top of the gearbox for the shift rods included in Marks kit (see pictures)
- Remove current gearbox
- Change Clutch for a new one if you dont know the history of it
- Remove Bell Housing from Old Geabox
- Countersink holes as shown in pictures below and you will need countersink screws and nuts
- Install stepper ring from Marks kit onto back of bell housing
- Install the studs onto each side of the Spacer in marks kit
- Install this spacer onto Getrag
- Push on bell housing and tighten up
- Install Gearbox & Shortened Propshaft with BMW Mounts and Marks Mounting Bracket (which i painted in several coats of hammerite)
- Mark supplied spacer plates for the gearbox mount but i didnt use these
- Install new speedo cable (part number is 211556 for a LHD car)
- Install Reverse Light Wires
- Fill with 90/90 Gear Oil
Note the lenght of shortened propshaft is 1195-1200 mm from flat face of flang at diff to spline at gearbox.
I did not butcher mine, instead got a second hand one from a saloon and had both pieces shortened.
Other Info:
- Part number of BMW Gearbox Mounts - 23711175732 x 2
- Speedo Cable from Speedy Cables in Wales
Not sure if I missed anything, if anyone needs more info, dont hesitate to ask!
