Guys, your help please.
I am in the process of replacing all the bearings and ball joints etc in the linkeage system. I have so far installed the new bearings in the cross over shaft and all ball joints and sockets above the engine. I am about to start on the joints at the pivot block on the side of the engine.
I am having problems at the moment with the engine speed returning to idle as the linkeages are binding just before the stop. I have isolated some of the problem to be the cross over shaft which is a tight fit in its bearings- there is no slop with the new bearings, (which is good) but it just seems to be too tight. I was wondering if there was a right and wrong way to install the bearings (they looked identical and symetrical to me), or whether I was supposed to hone them before I slid them onto the shaft.
Its an annoying problem. 50% of the time, once I let off on the accelerator, the engine will settle down to normal idle at about 800 rpm. Sometimes it settles at about 1200rpm, but if I blip the accelerator, it will drop down to 800. Worryingly, occassionally it will jam at about 2000rpm.
And a secondary question: if I remove the bottom linkeage bracket, will I loose any fluid - is it a special gasket? I do know that it will be a PITA to get at it to remove it!
George
