Author Topic: Oll filter  (Read 2982 times)
dseretakis
Oll filter
« on: June 10, 2010, 14:55:33 »
I have a few OEM Mercedes oil filters lying around.  I think but I'm not sure that they are for my pagoda. Part numberon box is A 000 180 00 09. Can anyone confirm if this is the correct filter for my 71 280SL?
mbzse
Re: Oll filter
« Reply #1 on: June 10, 2010, 15:44:42 »
Quote from: dseretakis
Part number on box is A 000 180 00 09. Can anyone confirm if this is the correct filter for my 71 280SL?
yes
Please ensure that the ring [(2) in diagram here] is present on your car
/Hans in Sweden
/Hans S
Re: Oll filter
« Reply #2 on: June 10, 2010, 16:34:59 »
Yes, thats the correct part  # for the Pagoda filter.
The seal ring pointed out by Hans is not a part of the filter kit.
It has to be purchased separately and does not need changing every time you replace the filter.
Have a look in the wiki for the seals that need changing periodically.
dseretakis
Re: Oll filter
« Reply #3 on: June 10, 2010, 16:43:06 »
Thank you all. I do recall the sealing ring from my last oil change. Thanks for the reminder.
