Author Topic: Another distributer question  (Read 3275 times)
jwalk
« on: June 16, 2010, 01:42:20 »
I am confused with the distributor JFUR6 0231 116 51on my 230SL engine  number 012501. Since the SL Group technical manual lists the correct rotor part number for both the -046 and the -051 distributors as 1234 332 088. How can this be, since the cam protrusion that the rotor fit to varies between these two. The -046 has a full length dia. of .560 inch from the cam, while the -051 is also .560 at the cam for a length of 1/8 inch and above that, for the length of the keyway the dia. is .510, or .050 smaller then the rotor bore.
Thanks for any help offered.
jwalk
Re: Another distributer question
« Reply #1 on: June 16, 2010, 11:39:59 »
Hi, jwalk,
The original Bosch part # for the rotor for the 046 distributor was: 1 234 330 062 but is not on a Bosch current list.
The 1 234 332 088 is still a good number on the Bosch list.
Beru use the same rotor for both applications: EV 4/6-Z, so I assume they are interchangeable.
Source:
http://www.automotive-tradition.de/download/ersatzteillisten/elektrik/ee_23_1_02_75/0231116.pdf
« Last Edit: June 16, 2010, 11:45:10 by naj »
