Author Topic: Connecting rods question  (Read 4018 times)
  • USA
« on: June 23, 2010, 19:36:27 »
Am wondering if the connecting rods from either a 250S (W108) or a 220SE (W111 sedan) are the same as the ones used in a 280SL motor.
Please let me know and I will run to get them from the motors.
Thanks so much.
Walter
1967 220SL-diesel
RickM
Re: Connecting rods question
« Reply #1 on: June 23, 2010, 20:29:45 »
With info derived from the Technical Section, http://www.detali.ru and Wikipedia (for 250S and 220SE engine numbers) the following is what I see.
Perhaps someone can verify.
Connecting Rod Part Number
280 SL (W113) = A 130 030 11 20
250 S (W108) = A 108 030 23 20
220 SE (W111) = A 127 030 01 20 and A 127 030 23 20 (Replaced by A 127 030 26 20)
« Last Edit: June 23, 2010, 20:35:26 by RickM »
RickM
« Reply #2 on: June 23, 2010, 20:31:18 »
« Reply #3 on: June 23, 2010, 21:30:52 »
Richard is correct. 250 series and 220 series will not work.  In addition I believe there is an early and late M130 connecting rod. these rods have a number cast into their side. Try to match yours. If yours are out, post  the number here so we can work on it. .
RickM
« Reply #4 on: June 23, 2010, 21:53:36 »
Joe, Out of curiosity, does the late version superseded the early piece or are there two distinct, non-interchangeable parts? Thanks.
« Reply #5 on: June 24, 2010, 04:41:29 »
Hello Richard,
I think the oil holes are in different places and even their rod bearings are different. If I get a chance I will dig some up and compare to be certain.
