Author Topic: need help sourcing fuse!  (Read 4976 times)
xcashewx
« on: June 27, 2010, 20:21:42 »
ive blown the 2 stubby fuses located on fuses 2 and 6.
ive tried miller, autohaus, all the regular sources and none of them carry them?
any ideas? :/
Re: need help sourcing fuse!
« Reply #1 on: June 27, 2010, 20:23:16 »
I would then try Classic Center, SLS, the other more specialized sources. Good luck, I'm sure all of us will eventually wind up where you are now.
gzmavian
« Reply #2 on: June 27, 2010, 21:11:06 »
I purchased some from the local Mercedes dealer who ordered and obtained them within two days.  I also believe another member may have mentioned that the Autozone may carry replacement fuses which will work but are not exactly the same as the MB fuses.
dtuttle123
« Reply #3 on: June 27, 2010, 22:25:36 »
There is some on e-bay in Germany - item no: 140421352707
« Reply #4 on: June 27, 2010, 23:25:41 »
Dave Gallon sells these also.
Witt
« Reply #5 on: June 28, 2010, 00:04:48 »
......Not being a "Purist", I replaced ALL my fuses with the German porcelain - type as used in all the older German cars......the different colour indicating their amperage.....I was working on older VWs for a living in a previous life...
CHEERS !
WITT !
RickM
« Reply #6 on: June 28, 2010, 21:32:15 »
Napa used to carry packs of the individual amperages. PepBoys used to carry mixed packs. YMMV, depending on location.
5 Amp = Yellow
8 Amp = White
16 Amp = Red
25 Amp = Blue
Witt
« Reply #7 on: June 28, 2010, 22:39:31 »
....That is correct....for all Canadian members try Canadian Tire Stores !
CHEERS !
WITT !
