Author Topic: Auto Shifting Problems  (Read 4044 times)
paul_GB
  • United Kingdom, England, Waterlooville
« on: July 03, 2010, 08:41:59 »
After a recent engine rebuild the auto box on my 230 was working sweetly (positive shifting at the right revs/load). During the latter stages of a recent long run it started to develop problems as follows :
1.  3rd to 4th change occurs at the correct revs but the transition is very slow (not a positive action)
2.  Pulling away in forward the gears only actually engage properly when I 'pip' the engine revs (and its clunky)
3.  Lower gear changes are now more clunky in general
4.  When pulling away in reverse the motion is now 'snatchy'
Good points :
1.  Kickdown works fine
2.  It stays in top gear once its there
3.  Changes happen at the correct revs
Ive checked and re-checked the oil level. Bolts all seem tight. Linkages all move ok.
Any thoughts..? Thanks..
Paul
1964 230SL - Dark Blue
merrill
Re: Auto Shifting Problems
« Reply #1 on: July 03, 2010, 12:15:15 »
Paul
see if this link helps
http://www.mercedesdismantlers.com/16BoltInstallationInstructions.html
They will answer questions via e mail if you need.
Regards
Matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
paul_GB
« Reply #2 on: July 03, 2010, 23:15:45 »
Thanks for the info Matt... very useful..
Cheers
Paul
Paul
paul_GB
« Reply #3 on: July 04, 2010, 17:40:37 »
.. after reading threads on this subject I am now suspicious that engine timing may be part (or all) of the problem. Ive seen Joe's comments suggesting timing can cause 'shifting' problems. I recently adjusted the cam sprocket timing (moved a link on the timing chain and installed a 4deg offset key). Hmm... could this be it or am I clutching at straws....? Thinking about it the transmission problems started about the same time. I need to undo the timing change and see if I get my slick gearbox back...
Paul
Paul
« Reply #4 on: July 11, 2010, 12:34:09 »
Hello Paul,
Since the automatic transmission is influenced from engine vacuum any change can cause shifting problems. Changes in ignition timing will cause a change in engine vacuum.
