I have a 1970 Euro spec 280SL. I ordered some replacement seat belts, and when to remove the old inside seat belts by loosening the bolts on the trans tunnel, when I heard something "drop". That made me think that their was a bolt nut on the inside of the the tunnel, in lieu of a threaded boss in the body pan itself.
I can't get access to this area, and the bolts no longer seem to anchor in here, confirming my suspicion that my seat belt bolts are no longer bolted in. The outer seat belts do have a threaded boss in to the body pan, and threaded fine.
Does anyone have any experience with installing seat belt bolts to the inner trans tunnel side of your interior? I have never seen someone use a bolt within a trans tunnel you can not access, it doesn't seem to make sense, and it could work loose, as opposed to a threaded boss in the body. So If I'm missing something, any enlightenment would be appreciated.
Scott B
1965 356 C Cab
