Author Topic: Hinge/door jamb  (Read 4265 times)
717-113
Hinge/door jamb
« on: July 06, 2010, 06:25:47 »
I'm trying to clean up some rust around the door hinge area. It looks like theres some sloppy welds, but I'm not to sure it thats how it should be. I looked around but couldn't find a really good picture of this area, could someone help me out with a picture of what it should look like? I've circled two spots I'm after in this picture I found. Might only really be able to see the bottom one with the door off
Re: Hinge/door jamb
« Reply #1 on: July 06, 2010, 12:49:56 »
Ah,
an early 230.
The upper area where the fender has been welded to the A pillar looks more or less correct to me. AFAIK there are no regular spot welding dots like on the inner upper lip of the fender towards the engine hood/engine bay.
All that area should be sprayed in body color.
Your hinge brackets on the A-pillar look like the early type for the aluminum hinges (without grease spot), thus that area should be original on your car too.
For everything else the res of the pic is too small.
John Lewenauer (TheLews) should have high resolution all-original-perfect-condition pictures on this area. ;) ;)
1971 230
1999 A4)
Re: Hinge/door jamb
« Reply #2 on: July 07, 2010, 05:24:15 »
thanks for the response. I looked through John's pictures and couldn't find a good enough shot :(. I Also noticed bpossel slide show is no up anymore :(?? (Used to be a good source for info like this)
  • USA, WI, Mequon
Re: Hinge/door jamb
« Reply #3 on: July 07, 2010, 20:02:45 »
Does this help?
Re: Hinge/door jamb
« Reply #4 on: July 08, 2010, 02:22:25 »
very very much so, the first picture is perfect. Hard to see on the second picture, but where it meets with the sill, theres no gap or anything correct? it welded right to the sill? Circled is the area I'm wondering about. Thanks
  • USA, WI, Mequon
Re: Hinge/door jamb
« Reply #5 on: July 09, 2010, 01:21:23 »
Sorry for the blurry one
Re: Hinge/door jamb
« Reply #6 on: July 09, 2010, 04:10:08 »
your the best john. thanks alot I hope you didnt pull your door off just for these photos :O  :-[
