Author Topic: fuel pump question  (Read 3761 times)
erickmarciano
  • Canada, Quebec, montreal
fuel pump question
« on: July 09, 2010, 03:38:41 »
why does my fuel pump have a conection there with a T one to the tank and on towards the engine?
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
George Des
Re: fuel pump question
« Reply #1 on: July 09, 2010, 12:30:29 »
The one you have pictured here does not have the T fitting that is used with the latest versions of the 113. The T fitting is used to help prevent vapor lock in the fuel system. The fitting is not normally used when installing the newer, small style fuel punmp on the earlier 113's that were originally equipped with the large style, older fuel pump.
George Desiderio
Jordan
  • Canada, ON, Jordan
« Reply #2 on: July 09, 2010, 14:00:36 »
I have the same fuel pump as pictured.  I recently had to change it and my return gas line has a Y junction, one line going back into the fuel tank and the other connected to the outlet you have you arrow pointed at (next to the larger fuel line from the gas tank).  Is this OK?  ??? ???
Marcus
66 230SL  Euro 4 speed
George Des
« Reply #3 on: July 09, 2010, 17:16:08 »
Jordan,
My understanding is that the use of the tapped fitting is not needed with the 230SL. I don't think it hurts anything though to have it tee'd and I'd just leave as is.
George Desiderio
Jordan
« Reply #4 on: July 09, 2010, 17:46:05 »
Thanks George.  Didn't think it was a problem, just wanted to make sure.
Marcus
