Author Topic: plastic tension rod holder  (Read 3458 times)
rmmchl
  • USA, WV, Charleston
« on: July 14, 2010, 01:29:50 »
does anyone have a close up picture or know which direction the grey plastic holder  is supposed to be screwed onto the bracket on the car body? . Also,I have 2 number 6 metric bolts and washers. screwing the rod holder on. I have seen pictures of 2 screws here instead. Does anyone know where I can obtain the number 6 metric screws for this application, if that's what supposed to be used?
michael romeo
1967  250sl
signal red
Re: plastic tension rod holder
« Reply #1 on: July 14, 2010, 13:42:22 »
Here are a couple... guess which ones mine...
« Last Edit: July 14, 2010, 13:46:08 by J. Huber »
« Reply #2 on: July 14, 2010, 23:38:01 »
 :o :o
Do I see this correctly??
John's grey holder  is broken ...??? Really? The high res pic suggests something like that. :o
Can't really see that clearly on James' car.
Early 230ies should have this "plasic tension rod holder" (nice word) with a metal base, not with a plastic base.
 :D ;)
« Reply #3 on: July 15, 2010, 00:42:49 »
Hi Achim, good eye as usual -- mine is a replacement part. I'll have to look at my old one to see if it was the original. And it does look like a crack on John's but maybe they were supposed to be that way  ;) ...
rmmchl
« Reply #4 on: July 15, 2010, 00:47:26 »
it sure is cracked
michael romeo
1967  250sl
signal red
