Author Topic: suspension bushes  (Read 4587 times)
gnj588d
suspension bushes
« on: August 02, 2010, 20:06:17 »
I am hoping to replace the rubber bushes on my 66 230SL,is this a job for the DIY.I think they are all the originals but there  is no knocks or squeaks from the car  but I suppose after 44yrs they need replacing.The engine mounts where done not so long ago, also I think the shocks may be original, whats the best way to tell if they are not performing correctly again there are no knocks or creeks,the car has done a documented 54k.Has anyone ever tried the polybush or nylon type bushes.Any info appreciated.Thanks Mike :-\
Re: suspension bushes
« Reply #1 on: August 03, 2010, 07:07:04 »
If you're going to change the bushes stick with the original material.
poly bushes will ruin the ride quality.
« Reply #2 on: August 03, 2010, 14:03:35 »
There could be some truth to that.
The only place I've used the poly bushings is on the front sway bar and the trailing arm. Neither of these places would change the ride quality very much but will help to stabilize the car.
menesesjesse
  • USA, MD, Indian Head
« Reply #3 on: August 03, 2010, 19:01:04 »
Does someone have a source for these or part numbers to order originals or aftermarket pieces? Thanks
Jesse
Jesse
1966 Mercedes 230 SL auto
2003 Mercedes E500
1992 Ford F150
1994 Ford Bronco
2019 Shelby GT350R
1967 Mercury Cougar XR7
xcashewx
« Reply #4 on: August 06, 2010, 20:48:01 »
autohausaz.com has a lot of the rear axle and some front suspensions rubbers at good prices.
