Author Topic: Oil Pump Replacement  (Read 6058 times)
bossanov
« on: August 10, 2010, 21:39:57 »
Seems the pump on my 71 280SL is binding.  Can anyone direct me to where to find a good used unit?  Old unit says "Febi" 9200 9232 9231"
B.
wbain
Re: Oil Pump Replacement
« Reply #1 on: August 11, 2010, 00:23:43 »
Why do you think it's binding? Have you had it out and tried to turn the drive ? Do you have low oil pressure? Have you had it apart and there are 'problems? Etc, Etc?
menesesjesse
  • USA, MD, Indian Head
« Reply #2 on: August 11, 2010, 03:43:18 »
Metric motors sells new ones but they are about 500.00.  They install them on all their rebuilds.
Jesse
1966 Mercedes 230 SL auto
2003 Mercedes E500
1992 Ford F150
1994 Ford Bronco
2019 Shelby GT350R
1967 Mercury Cougar XR7
« Reply #3 on: August 11, 2010, 04:35:41 »
Hello
As with Warren, I am curious as to why you think it is binding?
« Reply #4 on: August 11, 2010, 13:45:01 »
Apparently, the engine was run out of oil. That would make anything bind up! :o
bossanov
« Reply #5 on: August 11, 2010, 22:41:21 »
The engine is being rebuilt and the tech has been able to confirm a defective pump.
B.
« Reply #6 on: August 12, 2010, 04:54:11 »
Hello Bosanov,
A new oil pump on a rebuild is good to do as  a rule  and especially if you had a catastrophic engine failure. .
bossanov
« Reply #7 on: August 13, 2010, 14:46:46 »
Thanks all.  I decided on a new pump from Metric Motors.  Supposedly a high output replacement pump.
B.
« Reply #8 on: August 13, 2010, 18:23:26 »
Could you find out more, please, what this means "high output replacement pump" and let us know?
Is this hype or do they manufacture a different pump?  ???
bossanov
« Reply #9 on: August 13, 2010, 23:41:49 »
It is a different pump that bolts into the same spot.  From my visual comparison, the pickup area is smaller that the original.  I will take some side-by-side photos of both tomorrow and post them.  Mike at Metric Motors can provide more details.
B.
bossanov
Re: Oil Pump Replacement - Photos
« Reply #10 on: August 14, 2010, 01:00:46 »
Here are some images of the old and replacement oil pumps.  The older one with the larger pickup is on the left.
B.
