Author Topic: Dash lights  (Read 5746 times)
reggie
  • United Kingdom, England, Leeds
Dash lights
« on: August 18, 2010, 19:21:49 »
I spent a couple of hours putting some dash bulbs in, as soon as i changed one bulb it stayed on with no ignition  ??? So i looked in the hand book, It was brake warning light, so i thought hand brake is on no problem, I was just going to put it back together but thought il just check everything, I let the hand brake off and it was still on ? so i got out shut the door and disconected the fluid level warning lights, i looked through the window and it was off, So i got back in and it was on ? whats going on i thought, then it dawned on me its a door open warning light. No mention of that in the hand book. Felt a right muppet.  :-[
Reg
1969 280 5 speed zf 180g
Larry & Norma
Re: Dash lights
« Reply #1 on: August 19, 2010, 09:38:00 »
At least you sussed it in the end without tearing the whole car apart ;D
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
Ulf
Re: Dash lights
« Reply #2 on: September 02, 2010, 13:07:03 »
Can you change the bulbs without pulling the entire dashboard apart?
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
jacovdw
Re: Dash lights
« Reply #3 on: September 02, 2010, 13:14:04 »
Yes you can.
The 2 bulbs for the heater/ventilation levers can be changed by removing the speaker grille and speaker (if fitted), then you have good access to the 2 pods from above.
As for the instruments, can be easily accomplished from under the dash if you have small hands and some patience thrown in for extra seasoning...
reggie
Re: Dash lights
« Reply #4 on: September 02, 2010, 16:02:06 »
 I found taking the rev counter out quite easy, i think then its not too bad to get at the rest, upside down job tho, so no hangovers .
Reg
Ulf
Re: Dash lights
« Reply #5 on: September 12, 2010, 15:46:06 »
Small hands and patience? - I have neither, but will give it a go during the winter. I remember reading somewhere (probably this forum) that it is possible to go for brighter bulbs - a part number or a link to these would be "enlightening" (sorry about that)
Ulf
2008 Jaguar XF 3.0
2005 Mini Cooper
seawolf71
Re: Dash lights
« Reply #6 on: September 17, 2010, 16:12:40 »
I was able to get the speaker grill off,but the speaker itself,coverd with a wire mesh and some black fiber,won't come out .I pulled it off the two clips nearest to the windsheild-the the other two screws were missing- and when trying to raise the speaker up the magnet won't clear the dash. I don't want to damage it or the wood bows either so I'm open to any ideas. Bill 71 280SL
