Hi--
Answered my own question:
7) HYDRAULIC HOSES FOR BRAKES Equivalent to SAE-J1401
SPECIFICATIONS
S.NO ID OD WORKING TESTING BURSTING
PRESSURE PRESSURE PRESSURE
MM MM LBS PSI LBS PSI LBS PSI
1 3.1 10.6 2000 4000 8000
2 3.1 12.0 2000 4000 8000
3 3.1 12.5 2000 4000 8000
4 4.2 12.0 1500 3000 6000
5 4.8 13.0 1250 2500 5000
6 6.0 13.5 1250 2500 5000
APPLICATION
Hydraulic brake hose, use with non- petroleum base Brake fluid specified in SAE-J1403 f
CONSTRUCTION
Tube: Synthetic Elastomer inner tube to resist deterioration by non- petroleum based Hydraulic brake fluids.
Reinforcement:Two high strength rayon braids that resist internal pressure and dose not allows volumetric expansion
Cover: Black Synthetic rubber free from Sulphur, which will resist weather aging.
TEMPERATURE RANGE --40oC to +125oC
