Author Topic: fitting front shockabsorbers?  (Read 3439 times)
gnj588d
« on: August 26, 2010, 12:15:40 »
Can someone tell me how to fit the front shocks I am having trouble trying to compress the shock enough to insert it is there a special to needed.Thanks.Mike ???
Re: fitting front shockabsorbers?
« Reply #1 on: August 26, 2010, 14:01:16 »
Hello Mike,
There is a simple trick I use to install gas filled shocks.  Place a hose clamp around the rubber boot. Compress the shock. tighten the hose clamp so the shock stays in the compressed position during installation. Once you have the lower mounting in position release the clamp slowly and guide the top of the shock into its mounting!
I alwasy angle the lower mounting bolts on the front shock about 20-30 degrees off vertical prior to intstallation.  Also be careful not to release the front shocks until you are ready to guide the top of the shock into the mounting hole. If you miss the hole and hit the inside of the fender you could make an inside out dent in the body!
gnj588d
« Reply #2 on: August 26, 2010, 15:52:54 »
Thanks Joe brilliant idea job done panic over an absolute doddle now for the test drive with new shocks and anti roll bar bushes cant wait ;D.Cheers .Mike
gnj588d
« Reply #3 on: September 02, 2010, 21:54:50 »
the car drives like a brand new Pagoda,a totally transfomed 230SL.Brilliant.Many thanks.Mike.
