Author Topic: Definitive Hose Clamp List?  (Read 3901 times)
Kayvan
« on: August 29, 2010, 23:36:01 »
I have searched thru about 20+ Hose clamp posts for a definitive list of all the hose clamps under hood  and found these two (below). Do we or should we have a sticky item on this?  Its seems like the number will range (Beru, Cotter Pins or not, and # Yr, options P/S?)
Is Peter Lesller still supplying these? Or is there a supplier that sells sets? (Winzer site has sets for Norma clamps in Qty. min of 25?)
JohhnyB
I counted 55 clamps. To whit (using the very technical term of small, medium, large, etc. - and in no particular order) Also, I have an early 250SL with power steering and automatic. I don't believe any of the oil or fuel lines had clamps, they were fabricated lines with metal fittings for the connections.
Radiator lower hose - 2 large
Radiator lower small hose from expansion tank, 2 medium near the radiator and 2 more at the tank.
Overflow tank, line to top of radiator - 2 small
Overflow tank, clamps holding it in place - 2 XL
Radiator hose at top of radiator - 2 large
Hose at Thermostat - 2 med
Oil cooler line on left side of engine - 2 medium
Oil cooler line on right side of engine - 2 medium
Oil cooler line at Y - 2 med
Oil cooler line on upstream of Y - 2 med
Oil cooler left side of engine rear of cooler - 2 small
Heater (underneath) 2 med
Air cleaner - 2 XL
Fuel injenction thermostat - 6 small
Pwr steering 6 med
Breather pipe across the top of the engine - 3 med
Vacuum line to brake booster - 6 small (these are cotter key style on my car)
Cooling coil at air inlet - 4 small
Air idle adjustment hose - 2 small
Heater at firewall, right side - 2 med
Word Doc List
Coolant Hose Clamps
Radiator Hoses (6 clamps)
   Upper: 40 and 46mm
   Lower: 40 and 46mm
   Bypass: 40 and 40mm
FI Pump (6 clamps), MBZ hose 12x21mm
   Coolant lines (2): 18mm, 4 clamps
   Manifold line; 18mm, 2 clamps
Heater (8 clamps), MBZ hose 18x27, originally only 18x25
   Supply: 26mm, 2 clamps
   Return: 26mm, 2 clamps
   Expansion Tank to Pipe to Bypass: 26mm, 4 clamps
(the end at the Bypass hose is a real tight fit, probably needs a 28mm, the original hose was bigger at this end and is NLA)
Expansion Tank, MBZ hose 8x15 (originally 8x13? with 13mm clamp?)
   To Radiator: 15mm, 2 clamps
Other Hose Clamps
Valve cover rubber breather, 26mm, 1 clamp
Idle Circuit from FI pump to pipe, MBZ hose 12x21, 18mm, 2 clamps
Fuel Tank, with MBZ hoses
   Tank to Pump: 17mm, 2 clamps
   Pump to Chassis line: 15mm, 1 clamp
   Tank to Vent line, 12mm, 2 clamps
Fuel Lines in Engine bay (with original hoses, not replaced)
   Line to Filter: 15mm, 2 clamps
   FI Pump to Return Valve: 13mm, 2 clamps
Power Steering, MBZ hoses, ID 16mm x OD 23mm
   Reservoir to Box: original is Gemi 20/28, can use Norma 24mm, 2 clamps
   Reservoir to Pump: same as above, can use Norma 24mm, 2 clamps
Re: Definitive Hose Clamp List?
« Reply #1 on: August 30, 2010, 09:06:31 »
Kayvan,
we don't sticky these sort of topics... it's what the Technical Manual is for (http://www.sl113.org/wiki/Engine/HosesClamps).
Please update the Technical Manual if you have new insights.
