Thanks. Great advice Jaco. Job completed, correct spring installed in correct location now (between dist shaft and helicoil drive), Timing, Dwell angle all set up fine and engine runs well and idle was nice and smooth too (at 800 rpm). In fact the best Ive ever had it. But after a few miles the rough idling is back so need to look elsewhere now.. valve settings is next (as per Naj's suggestion)..
