Author Topic: Hard top seal  (Read 3472 times)
gnj588d
Hard top seal
« on: September 08, 2010, 07:48:49 »
Just fitting a new front seal to the hard top should it be just pressed in or glued as well.Thanks.Mike. :-\
Ulf
Re: Hard top seal
« Reply #1 on: September 08, 2010, 11:26:55 »
I've just pressed mine in and it really sits firmly - it's easiest with the hardtop on the floor upside down (on a thick carpet or pillow to avoid scratches), fill in the rear lip into the groove while pressing in the front one with a pointed instrument (not too sharp as it might slip) - it only takes a few minutes to do  ;)
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
gnj588d
Re: Hard top seal
« Reply #2 on: September 09, 2010, 07:55:21 »
Thanks Ulf job done just got to get a few mates to lift it on.Thanks again.Mike.
Ulf
Re: Hard top seal
« Reply #3 on: September 09, 2010, 09:40:21 »
You're welcome - hopefully the new seal will also reduce wind noise :)
Btw - you only need one mate to help put it on, but why not make it into a social event?
Ulf
2008 Jaguar XF 3.0
2005 Mini Cooper
