Author Topic: Torn rear axle bellows seal  (Read 3186 times)
IXLR8
« on: September 16, 2010, 15:03:29 »
Hi--
I am restoring a 65 230SL that has been neglected.
The rear axle bellows seal is torn, and has been apparently for some time.
If any dirt has gotten into the rear axle because of this faulty seal, what is the best option to ensure that it is flushed out?
After replacing the seal, should I flush out the rear axle through repeated fillings and draings of the lubricant, or what?
Thanks in advance for your help.
Joe
Re: Torn rear axle bellows seal
« Reply #1 on: September 18, 2010, 04:40:34 »
These units are quite durable howevers, if you are afraid the unit has be contaminated with sand or dirt, I would flush it with grease right after a short drive. Otherwise you may want to change the diff oil after a few thousand miles if you are uncertain that  dirt may have entered the unit.
IXLR8
« Reply #2 on: September 18, 2010, 12:02:45 »
Thanks, Joe
When you say flush it with grease, how do I do that?
Joe
« Reply #3 on: September 19, 2010, 03:30:57 »
Sorry Joe, I am  refering  to 90 W gear oil. (often refered to as grease)
IXLR8
« Reply #4 on: September 19, 2010, 14:54:18 »
Thanks, Joe.
As Frankie Vallie sang, "Grease is the Word"
Joe
