Author Topic: Picture of under-cowl area needed  (Read 4527 times)
ctaylor738
  • USA, VA, Falls Church
« on: September 23, 2010, 21:59:15 »
Continuing to plod along on re-assembly in the dash/cowl area.
Does anyone have a picture, descrption, or PNs of the fittings that secure the cables as they pass through this area?  I am assuming that the little tabs welded to the shell have some sort of cable clamp, but nothing is exactly leaping out of the parts pile and the EPC is not a lot of help.
Picture attached.
« Last Edit: September 23, 2010, 22:00:49 by ctaylor738 »
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
Re: Picture of under-cowl area needed
« Reply #1 on: September 24, 2010, 05:21:48 »
Hello Clay,
The tabs hold little flat leaf spring clips.  They are used on the other end of the cables in the dash also if I recall correctly. They are quite common to the era in sedans etc. If you need some let me know and I can pick a handful from the "south forty" for you. May be able to snap a picture for you in the next day or two.
Take care,
Joe
Bernd
« Reply #2 on: September 24, 2010, 13:25:40 »
See attached pics. They are not normally painted but cad plated. Sorry, don't have P/N's either. Hope that helps
parry
  • United Kingdom, England, Great Leighs
    • Lux Classics
« Reply #3 on: September 24, 2010, 21:59:17 »
Lock plate for bowden cables - MB Part number 006 799 004 001.
Part number not showing on MB Classics Parts Portal but showing available from SLS  Product No: 775158
Regards
Parry Chana
Lux Classics  Mercedes-Benz Restoration
1970 280SL LHD USA import in restoration
1968 280SL RHD to start
1969 280SL RHD totally original
ctaylor738
« Reply #4 on: September 26, 2010, 12:02:29 »
Thanks, guys.  I do have some of those clips.  They are in the EPC, as "Lock plate."
All ot the handles in my heat/vent control unit are broken, one of the plastic lights is broken, and the cables are frozen.  So I sucked it up and bought a new one from MB.
I will post some pictures of the cable clamps next week.
Cheers,
« Last Edit: September 26, 2010, 12:08:21 by ctaylor738 »
Chuck Taylor
1963 230SL #00133
Falls Church VA
ctaylor738
« Reply #5 on: October 04, 2010, 12:09:21 »
Here's a picture of the cables and clamps installed with hardware store grommets since the MB part was on backorder.  Also got the new heater/vent control installed as well as the outside vent and grille assembly.
Chuck Taylor
1963 230SL #00133
Falls Church VA
