Author Topic: Automatic gearbox linkage  (Read 3519 times)
Larry & Norma
« on: September 29, 2010, 11:09:09 »
Just to illustrate what happens if you fail to renew the linkage bush after 40 years as I found out
half way up a mountain in France.
The third picture is the replacement in situ.
The last picture is the improvised tool for pulling the bush into the arm then
with a little silicon grease pliers are used to assemble the two parts.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
badali
  • USA, Pa, Butler
  • 1966 230SL
Re: Automatic gearbox linkage
« Reply #1 on: September 29, 2010, 21:58:47 »
I recently had the same problem.  I pulled the shift lever from inside the car.  There is a bushing at the top that is the same.  I like the tool idea you have.  It would have saved me some time.
Brad
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
Larry & Norma
« Reply #2 on: September 30, 2010, 07:54:56 »
I had previously done the top bushes when I changed the bulb in the shift gate,
thought the bottom bush felt good but got that wrong!!
2023 Ioniq6
2005 C230
Coops
« Reply #3 on: October 01, 2010, 11:00:42 »
Mine went in the middle lane of the "periferique" ring road round Paris. Imagine how pleased the French were about that! I did manage to limp it home.
