Author Topic: Lost ignition Key  (Read 4651 times)
louisz
Lost ignition Key
« on: October 04, 2010, 16:55:46 »
Im new here and I have a problem.  I lost the ignition key while my car was in storage.  The steering is locked and I have searched for a new ignition cylinder.  I am unable to find one for a 71280sl.  The only ones I have forund are for a 280SE...Will those work?
is there anyone who can make me a new key with my VIN #?
any help
Thankls
bogeyman
  • USA, NE, Omaha
Re: Lost ignition Key
« Reply #1 on: October 04, 2010, 18:33:48 »
You can go to your local dealer with proof of ownership and serial# and they will order a new key for you.
The only caveat is that your vehicle has not had an ignition lock change.
Rick Bogart
1969 280SL Silver(180)/Green
1993 500E
1972 350SL
1995 E320 Cabrio
louisz
« Reply #2 on: October 05, 2010, 19:15:06 »
Thanks, Ill try that but looking at the metal dash panel, it looks like someone may have changed it before.
« Reply #3 on: October 08, 2010, 03:32:22 »
You may be able to have a locksmith make a new key to fit the door handle, the handle is easily removed by taking one screw out behind the weatherstrip. The doors on a 71 280sl if original are keyed the same as the ignition. I'd reccomend taking out the right side handle as it will have less wear than the drivers side.
« Last Edit: October 08, 2010, 03:34:59 by al_lieffring »
« Reply #4 on: October 13, 2010, 21:58:21 »
Hi Louis,
You might also want to get in contact with Jim, he should be able to help you.
See here:
http://www.sl113.org/forums/index.php?topic=13302
Good luck &
