Author Topic: automatic not shifting into 4.  (Read 2426 times)
oliver33914
« on: October 28, 2010, 18:17:42 »
my automatic transmission (69 280 sl) is not shifting into the 4. gear, 1,2,3, no problem but not the 4. any suggestions what to look for?
Coops
Re: automatic not shifting into 4.
« Reply #1 on: October 28, 2010, 19:56:54 »
Two things:
You know that the box only uses 2 - 3 - 4 in normal driving so you will only feel 2 gearchanges as the car will only start in first with the select lever in 2nd or kickdown?
Secondly make sure that the linkage between the box and the select gate is correctly adjusted and that the transmission is not blocked in third.
Rgds, Martin
