Hauser,
Lowering the idle should be done with a complete review of the linkages, air/fuel mix, a check of the timing/advance, etc. You can lower the RPM a couple of different ways (like just backing off the air coming through the air intake-a simple turn of a screw driver), but could hurt the performance in another way. So not an easy answer.
