Author Topic: heater lever control housing unit rebuild - lubricant required ?  (Read 3410 times)
pmo956f
Hi ,  spent this evening stripping and reassembling my  heater control lever assembly, replacing broken levers etc .. :)
should the unit be lubricated , ie where the levers rotate around the clear plastic cylinders and where the cable holding nuts sit in there grooves on the metal frame
if so whats best to use ? (i have the coloured clear levers  a la 250sl)
Thanks in advance !
Re: heater lever control housing unit rebuild - lubricant required ?
« Reply #1 on: November 02, 2010, 22:22:55 »
On the cables use a light oil or a oil/graphite spray.  Heavy grease and oil will attract dirt and grime and will become thick and sticky in cold weather. Be careful using lubricants on the plastic parts. Some lubricants will attack the plastic causing parts to fail in the future. I suspect that Mercedes may not have used lubricant on the plastic parts which must remain clean and clear to tranfer light to the front of the controls.
pmo956f
« Reply #2 on: November 03, 2010, 23:38:05 »
 ;) great ,  thanks for your help JA ..
