Author Topic: Recommended Lubricants?  (Read 3097 times)
GAJIM
« on: November 17, 2010, 04:04:26 »
Although not new to caring for and servicing cars, trucks, and machinery, I am new to the forum and recently purchased a 4 speed '69 280SL.
Can you advise which brand/weight of motor oil, gear oil, etc. to use? The engine is still tight, runs great, and seems to not use hardly any oil.  I've had the car for 3 months and the oil level has not moved on the dipstick.  I am curious to know what other recommend to use for motor oil, transmission gear oil, rear end gear oil, etc.  Do you recommend adding ZDDP to the oil?  Is this necessary?  I plan to service the car myself.  Thanks,  GA Jim
Re: Recommended Lubricants?
« Reply #1 on: November 17, 2010, 22:46:00 »
Welcome to Pagoda ownership and to the Forum,
If you use the search feature, you should find a large amount of (oft times divergent) advice regarding engine oil. I would advise you to take a look and read through the comments.
