Author Topic: Sheet Metal Replacement  (Read 4509 times)
gboyd
« on: November 19, 2010, 04:32:11 »
Hello:
I'm new to the forum.  I have a general question about the purchase of a '70 280.  I am looking at a car that had been restored back in 1985.  Back then the owner noticed rust on the front and rear sheet metal panels.  So he had the car "restored" by replacing the sheet metal all around the car (not the hood, doors or trunk).  My question is this.  How much of a negative impact on the value of the car is there given that most of the metal is not original?  Should I be concerned about anything?
Thanks for any input.
Greg Boyd
Ulf
Re: Sheet Metal Replacement
« Reply #1 on: November 19, 2010, 11:42:16 »
Replacing rusty panels with new ones is a much better operation than merely fixing the rust spots with Bondo etc. If the work was done properly and all panel gaps are nice and even, I see no problem. But it all really comes down to whether you are looking for an original car (they are very rare after 40+ years) or a sound and rust free driver :-)
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
gboyd
« Reply #2 on: November 22, 2010, 18:44:27 »
Thank you.  I would like to get some advice from an expert on what I should pay for this car.  Can you recommend anyone that I could send some detailed pictures to and get an high level perspective on the price range I should consider?
Greg
dseretakis
« Reply #3 on: November 24, 2010, 01:01:53 »
It all depends upon the quality of the repairs. How was the sheetmetal replaced? Was it riveted, glued or welded? If welded, was it butt welded? If butt welded properly then this shouldn't have much impact on the value of the car. You may not have the answers but some restorations are well documented with photographs. Nothing of course can beat a clean  original rust free car in terms of value.
gboyd
« Reply #4 on: November 24, 2010, 04:08:16 »
It was very well done and welded.  Not sure what type of weld. The owner documented the work in many pictures.
Ulf
« Reply #5 on: November 24, 2010, 07:30:15 »
Upload the photos, so we can see them - not an expert on US prices, but it's easier to tell when you see the car :-)
2008 Jaguar XF 3.0
2005 Mini Cooper
Jordan
  • Canada, ON, Jordan
« Reply #6 on: November 24, 2010, 21:13:23 »
Greg,
Buds Benz are located in Douglasville, GA, about 40 minutes from your place if you are in Marietta.  Talk to them and they may be able to help you out with an evaluation or an inspection.  They specialize in these cars.  I have no affiliation with them but worth a phone call at least.
Marcus
66 230SL  Euro 4 speed
