Author Topic: Wood Speaker Cover - Need Description of Screws  (Read 4078 times)
JPMOSE
  • USA, DE, Harbeson
« on: November 21, 2010, 15:54:13 »
I have a small pile of screws and can't figure out which two are for the speaker cover!   Could someone describe approximately what length and finish the subject screws are?
I'm usually so good about marking and separating items but blew it this time.  Thanks in advance!
Best Regards,
J. P. Mose
1968 250SL
1970 280SE 3.5 Cabriolet
1987 560SL
Re: Wood Speaker Cover - Need Description of Screws
« Reply #1 on: November 21, 2010, 18:02:42 »
They're quite unusual screws; around 20mm long self tappers, chrome plated and thin (around 2mm).
If you gt stuck I can provide you with MB part number.
JPMOSE
  • USA, DE, Harbeson
« Reply #2 on: November 21, 2010, 18:20:46 »
Thanks....then that means I found one of the two!   I have the part number but it is NLA (at least is was for my 280SE 3.5...I'll check the EPC and see if they're the same part number).
Best Regards,
J. P. Mose
1968 250SL
1987 560SL
« Reply #3 on: November 21, 2010, 18:47:48 »
Lens head countersunk screw DIN 7983 22x2.9 mm
blunt end, not self-tapping!
« Last Edit: November 21, 2010, 18:49:54 by 66andBlue »
JPMOSE
  • USA, DE, Harbeson
« Reply #4 on: November 21, 2010, 18:54:42 »
A picture's worth a thousand words!  Thanks to both of you!
Best Regards,
J. P. Mose
1968 250SL
1987 560SL
