Author Topic: Hardtop weight?  (Read 3077 times)
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
Hardtop weight?
« on: December 01, 2010, 17:00:38 »
I know there is a 110 lb difference between hardtop and softtop overall weight of the car... but what does the hardtop weight?  I assume there are less pieces with the softtop gone so I do not think the 110 lb difference is the true weight of the hardtop.  Thanks also does anyone know of a good cartage company I need to ship the hardtop.
As always Thanks, Bob :)
Bob "Baron" Youngman
1965 220se coupe restomod
Re: Hardtop weight?
« Reply #1 on: December 01, 2010, 17:42:59 »
The 49 kg = 108 lbs is not the difference between hard and soft top weight but how much you need to add to the weight of the car when you mount the hard top.
http://www.sl113.org/forums/index.php?topic=5283
If you believe that the number is wrong then just put it on a scale and let us know.  ;)
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
Re: Hardtop weight?
« Reply #2 on: December 01, 2010, 19:00:06 »
ok sounds good I guess it just seems heavier because it is so bulky.
Thanks, Bob :)
