I got the following from a post by George Davis;
The idle fuel adjuster engages a slot inside the pump when it’s pushed in; when it’s not engaged in the slot, it simply spins free.
To increase the idle fuel, turn the adjuster clockwise, as if you were facing forward.
To decrease the idle fuel, turn the adjuster counter-clockwise.
If I'm standing beside the car on the left side facing forward then turning the know to the right would CW and to the left CCW. Given this, which way should it be rotated to decrease fuel?
Doug Goins
