Author Topic: ivory colour code for steering wheel ?  (Read 3714 times)
pmo956f
« on: December 07, 2010, 10:19:15 »
Hi , would anyone happen to know if there is a colour code to match the ivory steering wheel  colour ,  also would the selector lever or any other parts be in the same colour with this ivory  option?
thanks in advance  ;)
PMO
Re: ivory colour code for steering wheel ?
« Reply #1 on: December 07, 2010, 15:20:02 »
I've been trying to develop a re-casting service for these wheels; the moulds are made and very successful but I can't find the correct material to cast them in. Any suggestions anyone?
« Reply #2 on: December 19, 2010, 02:09:23 »
Hello Stick,
I used to use cold casting resins from this company.  http://rudolphbros.com/products/product.php?c=7&p=16   they are not close to you but you may be able to get some information from their web site.
Pure urethane resins are tough and impact resistant, but hard on silicone molds since the urethane material sticks tenaciously to anything it touches. Most can be colored to match your sample.  A modified or filled urethane resin like their "Pro Cast" resins is easy  on molds, easy to work with, work fast and shrinkage is minimal, but it is not nearly as impact resistant and not good for color. Epoxy casting resins can also be a possibility also, but is harder to work with and hard to color.
