Author Topic: Distributor Oil Cup - Cap turns Freely  (Read 3656 times)
JPMOSE
  • USA, DE, Harbeson
« on: December 14, 2010, 18:29:16 »
Quick question:   Should the cap (with small hole), that covers the oil cup on the side of cast iron distributor, be able to turn freely?  It took some force to get it to turn (probably due to time) but it doesn't get tight when turning clockwise.
Thanks for your time!
Best Regards,
J. P. Mose
1968 250SL
1970 280SE 3.5 Cabriolet
1987 560SL
Re: Distributor Oil Cup - Cap turns Freely
« Reply #1 on: December 14, 2010, 18:54:40 »
On my distributor (051), the oil cup assembly consisted of two parts. The base is the part that press fits into the distributor casting and has a fill hole. The cap is permanently crimped onto the base and has a fill hole that matches the base. The cap simply rotates around on the base. To add oil, rotate the cap until the two holes line up. When finished, rotate cap 180 degrees to cover the hole in the base. The cap never tightens down but should not be very loose either.
  • USA, WI, Mequon
« Reply #2 on: December 14, 2010, 19:06:46 »
yes
JPMOSE
  • USA, DE, Harbeson
« Reply #3 on: December 15, 2010, 05:42:43 »
Then I'm good to go!   Thanks guys and have a great holiday season!
Best Regards,
J. P. Mose
1968 250SL
1987 560SL
