Author Topic: Locking Gas Cap..?  (Read 11111 times)
MRB43
Locking Gas Cap..?
« on: December 22, 2010, 07:19:48 »
Where is the best place to find a locking gas cap for my '70 280SL like the one in the attachment ?
Is this one "authentic" as per what was offered as an option in 1970 ?
Would my car require a vented or a non-vented gas cap ?
Thanks.
Re: Locking Gas Cap..?
« Reply #1 on: December 22, 2010, 07:42:30 »
Classic Center
Call Tom or Jon at 949-598-4842 ask for the MBCA discount (15%)
Jordan
  • Canada, ON, Jordan
« Reply #2 on: December 22, 2010, 12:27:48 »
Get ready for some sticker shock.  Nice Christmas present to give yourself.
Marcus
66 230SL  Euro 4 speed
« Reply #3 on: December 22, 2010, 15:54:13 »
Ditto on the sticker shock. But they look so nice!
« Reply #4 on: December 22, 2010, 17:13:40 »
What's even more of a shock is when you loose both keys to your new cap after putting it on the car and running empty.  That's what recently happened to a friend of mine.
Dave Gallon
  • USA, NC, Statesville
« Reply #5 on: December 22, 2010, 18:39:13 »
The gas cap is not ventilated. As your car is a 1970, it should be a "one-key" car. That would make the cap a 000 471 47 30. It can be ordered custom keyed to match the rest of the locks on your car. The current MB USA list is $284. Shoot me an email (dgallon@cox.net) if I can help further.
Dave Gallon
Dave Gallon
Gallon Restorations
113.044-12-001155
jaymanek
« Reply #6 on: January 08, 2011, 16:27:34 »
When i ordered a new one for my Pagoda I was told it could no longer be ordered to match the car key so I had to get one with new keys... It was around £250 GBP mark.
ctm14
« Reply #7 on: February 23, 2012, 05:07:03 »
Has anyone had luck ordering a locking gas cap to match the original keys based upon the data card code?  I see Dave Gallon mentions this can be done in this thread but Tom Hanson at the Classic Center advised it was nearly impossible. I trust Tom but wondered how Dave was able to do this in the past. I hate to add that fourth key if I can avoid it.
Jordan
« Reply #8 on: February 23, 2012, 11:05:37 »
Contact Dave directly.  His e-mail is above and his phone number is in the suppliers section.  You live in the same city so you could also go see him.
Marcus
« Reply #9 on: February 23, 2012, 14:50:05 »
It's a relatively simple matter to modify the lock to fit your key and if you don't want to tackle it any competent locksmith should be able to do it.
ctm14
« Reply #10 on: February 23, 2012, 17:24:52 »
Thanks Guys,
  I have tried to contact Dave directly but no response, perhaps he is busy with all the firewall pad orders.  I also read a post describing how the new caps could not be disassembled so thought it wouldn't be possible for a locksmith to re-key.  Has anyone re-keyed since the caps became difficult to disassemble?
« Reply #11 on: February 23, 2012, 18:18:54 »
 .....  I also read a post describing how the new caps could not be disassembled so thought it wouldn't be possible for a locksmith to re-key.  Has anyone re-keyed since the caps became difficult to disassemble?
I bet you did not read this in the technical manual! Correct?
The lock cylinder is easy to take out: http://www.sl113.org/wiki/Fuel/LockingGasCap
If you have a double-sided car key and the gas cap uses a double-sided key then a locksmith should be able to change the pins to fit that key.
« Last Edit: February 23, 2012, 18:28:22 by 66andBlue »
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
« Reply #12 on: February 23, 2012, 18:32:29 »
I ordered my locking gas cap with matching keys about 4 months ago. Sticker shock is right! I ordered mine through the local Mercedes dealer with the club discount. The nice thing is it came with two additional keys.
- 2024 Mercedes GLE 350
- 2024 AMG C43 Sedan
ctm14
« Reply #13 on: February 23, 2012, 20:25:34 »
Alfred you got me  ;D.  I often read the technical manual but in this situation just relied on forum posts.  Big mistake the tech manual is very informative on this topic.  Even better though is 71Beige's response that he was able to order a cap with matching keys.  I will look into that further and know I have the locksmith option as well.
Thanks!
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
« Reply #14 on: February 23, 2012, 22:01:59 »
The parts person at the dealer needed my VIN. I understand it came from Germany. Took about 2 1/2 weeks to get it. I don't remember what it cost but I keep all receipts. I want to say it was a little over $300.00. Expensive but, looks great. You MUST REALLY twist it on to ensure the cork creates a tight seal and the cap doesn't fly off.
George Des
« Reply #15 on: February 23, 2012, 23:05:08 »
I was able to rekey mine so the glove box key works it. Takes some fiddling around but with some help from Joe A I was able to do it with a minimum amount of cussing.
George
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #16 on: February 23, 2012, 23:13:36 »
Put a few drops of oil on the tabs and spring part of the cap and it will go on and off easier.
« Last Edit: February 24, 2012, 13:25:21 by badali »
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
« Reply #17 on: February 24, 2012, 13:16:35 »
Thanks for the tip badali!
glenn
« Reply #18 on: February 24, 2012, 19:34:49 »
Re:huf gas cap...    Can the indentations be drilled out?  This would release the key piston out of the cylinder??   Can this be done?
Thanx
