Hi All,
Well to prove that no good deed goes unpunished, I have managed to turn my previously well running 280SL into one that won't even start.
Was poking around the power steering pump and hoses to try to ID a leak, so I had the battery out. Got everything cleaned up, hose clamps tightened (they were all a little loose), then replaced the battery. In doing so, I had to loosen the dist to turn the vac advance housing out of the way to make room for the battery to slide in.
Got everything put back together, started the car, and got ready to set the timing with a strobe. Then I realized I hadn't pulled off the vacuum hose, so did that but also moved the dist a bit.....engine stalled.
Now can't get a hint of an ignition. Have set the timing to approx 7 to 8 deg BTDC according to the timing marks and attempting to line up the rotor over the mark on the distributor body.
Replaced the plugs with NGK BP5ES, gapped to .028, let the car sit for a few hours with the plugs out to see if I had flooded it. Checked the spark on two plugs (5 and 6)..good spark.
Don't know what to do next!
I'll try to attach pics of the timing marks and the rotor/distributor body for reference.
