Become a
Full Member
Emergency Contact List
Drum Brake detailed exploded diagram
Topic: Drum Brake detailed exploded diagram (Read 5138 times)
seattle_Jerry
January 02, 2011, 01:17:35 »
Anyone have a detailed diagram of the rear brakes. The PO put the brakes together wrong and missing pieces so things aren't lining up right. The one adjustment bolt doesn't seem to do anything either.
seattle_Jerry
Re: Drum Brake detailed exploded diagram
January 02, 2011, 01:23:08 »
is the order on the pivot:
Spring, flat washer, brake shoe, brake shoe, flat washer, bolt
and the two adjustment bolts:
cupped washer, spring, flat washer, brake shoe, flat washer, pin
seattle_Jerry
Reply #2 on:
January 02, 2011, 03:55:51 »
I found one for the pivot bolt...nothing for the adjustment bolts as of yet
merrill
Full Member
Platinum
USA, TX, Austin
Reply #3 on:
January 02, 2011, 15:02:40 »
see if this link helps
http://www.sls-hh-shop.de/index.php/cat/c3_Mercedes-Benz-230SL-250SL-280SL-Pagoda--R113-W113-.html#cat_70
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
badali
Full Member
Platinum
USA, Pa, Butler
1966 230SL
Reply #4 on:
January 02, 2011, 22:47:18 »
Here are some pictures I took before I replaced mine so I could get them back together.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
badali
Full Member
Platinum
USA, Pa, Butler
1966 230SL
Reply #5 on:
January 02, 2011, 22:48:14 »
more pics
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2025 E53 AMG Sedan
