Author Topic: What fuel to use  (Read 4119 times)
GroovyTiggr
What fuel to use
« on: January 12, 2011, 12:18:52 »
I just bought my first Pagoda (230sl '64) and want your advice on which fuel to use.
The guy I bought it from told me I could use EURO95 fuel. I already read on this forum that in France (for example), E10 (ethanol) is added and that this is harmfull for the car.
I know there are some substitutes for the fuel with lead (plomp) are those recommended to be used?
Please enlighten me.
Ulf
Re: What fuel to use
« Reply #1 on: January 12, 2011, 13:49:03 »
I'm running fine on 95 octane unleaded. There are a lot of opinions on whether it is necessary to use lead-substitute additives or not, as the valve seats are hardened already. I use it every second time I fill up. I haven't heard that the ethanol should be harmful - but up here the fuel only contains 5% and not 10...
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
GroovyTiggr
« Reply #2 on: January 12, 2011, 14:08:26 »
Thanks for your respons Ulf.
This is where I read about the ethanol fuel:
http://www.sl113.org/forums/index.php?topic=11150.msg74455#msg74455
« Reply #3 on: January 13, 2011, 21:59:53 »
As far as I know there is consensus ("overeenstemming") here that unleaded fuel is fine, no lead substitutes necessary.
1972 Lancia Fulvia Coupe 1.3
joelj
« Reply #4 on: January 29, 2011, 14:38:17 »
Great Im gald to know that there is no concern regarding our w113 and unleaded fuel. I did read that there is an additive available but if you guys say there is not need then i won't worry about it
