Author Topic: How much is too much Distributor Timing  (Read 21238 times)
Re: How much is too much Distributor Timing
« Reply #25 on: September 20, 2012, 07:50:13 »
Sometimes it's necessary to live with a small air bleed past the cold start valve if one is to avoid a fairly large expense. One can compensate with the idle air screw. They both have the same function but achieve it in different ways.
Jkalplus1
« Reply #26 on: September 20, 2012, 09:41:15 »
Thanks again for taking the time to answer me, much appreciated.  I will check it out. Is it complicated to adjust?  The Technical manual does not talk about it.
Jerome
« Last Edit: September 20, 2012, 09:50:12 by Jkalplus1 »
