Author Topic: rubber strips for 3.5 coupe  (Read 6911 times)
douglas dees
« on: January 19, 2011, 19:43:03 »
Does anyone have the 2 rubber strips for the 280 SE coupe for the front bumpers?
Doug Dees
JPMOSE
  • USA, DE, Harbeson
Re: rubber strips for 3.5 coupe
« Reply #1 on: January 22, 2011, 21:42:10 »
Doug,
I don't have them but wanted to let you know that I've been in touch with the Classic Center about this material (it is cut to fit - front and back).   It is no longer available, but they are going to trying and contact the original manufacturer and find out if they have stock or plan on doing another run.   If I hear something, I will let you know.
Best Regards,
J. P. Mose
1968 250SL
1970 280SE 3.5 Cabriolet
1987 560SL
« Reply #2 on: January 23, 2011, 13:53:53 »
Most likely this rubber profile is the same as a W108 and W109 sedan of the era. The lengths are most likely different. You might possibly be able to cut to fit some good used sedan rubber strips.
« Reply #3 on: January 23, 2011, 15:06:30 »
The 108 front bumper rubber strip has molded ends where on the later 111 coupes the ends tuck in beneath a hole in the bumper, so if the molded ends were cut off it would be too short. a possibility might be using the 108 rear bumper strip that runs all the way across. It could possibly be cut off to length to fit the coupe's front bumper.
When I owned a 67 250 coupe with the early chrome only bumpers, it had poorly rechromed bumpers, I installed 108 bumper strips to hide the wavy chrome finish, I imagine I used some kind of "T" bolts to attach it. The strips looked so similar no one ever noticed the difference
« Reply #4 on: January 23, 2011, 16:34:18 »
Bob Hatch has various W111 parts for sale.
http://hatchandsons.com/pages/parts/
douglas dees
« Reply #5 on: January 25, 2011, 18:18:38 »
Al
I looked at the W 108 bumper strips on the coupe and the slot appears to be narrower than that of the 280 SE 3.5 so I don't think the old strips will work.
Doug Dees
« Last Edit: January 26, 2011, 09:30:37 by Peter van Es »
JPMOSE
  • USA, DE, Harbeson
Best Regards,
J. P. Mose
1968 250SL
1987 560SL
