Author Topic: fuel injection pump calibration  (Read 3780 times)
nadeem
« on: January 22, 2011, 05:32:32 »
any body can help me for the exact fuel calibration of 250sl injection pump R18. how much is the quantity of fuel in ml at different RPM. what is the permissible difference in fuel from each plunger of pump.
jacovdw
Re: fuel injection pump calibration
« Reply #1 on: February 04, 2011, 17:34:41 »
Hello Nadeem,
The exact calibration data is not freely available and was never made available to members of the public outside of Bosch repair shops.
However, from time to time literature from Bosch pops up on fleabay.
Unless you have access to and experience to use the specialized equipment necessary to properly calibrate the mechanical fuel injection pump, I would not recommend trying it yourself.
If you do not have access to the necessary equipment, then you can consider sending the fuel injection pump to Koller in Germany.
Have a look at their website: http://www.koller.de/
Hope this helps.
« Reply #2 on: February 04, 2011, 21:05:41 »
Hope your German is good!
Large size so you cn copy and print.
Naj
« Last Edit: February 04, 2011, 21:07:47 by naj »
nadeem
« Reply #3 on: February 05, 2011, 06:12:11 »
i will try to get a German who can translate the page for me however i think it will be helpful for me.
thanks
