Author Topic: Light Bulbs  (Read 4441 times)
tel76
Light Bulbs
« on: January 27, 2011, 22:25:41 »
I am having great difficulty in obtaining the 12v 18w bulbs that are fitted to the indicators/flashers, does anyone have the MB part number or the equivalent manufacturers name and number.
The advance and retard plastic pipe is clipped to the CSD fuel supply pipe with 3 clips,does anyone have the part number for these clips?
Eric
jacovdw
Re: Light Bulbs
« Reply #1 on: January 28, 2011, 06:19:00 »
Hello Eric,
If the clips you are referring to are c-shaped with a little bulge at the back, then the part number would be: A180 993 05 25.
According to the EPC, the part number for the bulbs should be: N072 601 012 160.
I can however not confirm whether it is in fact 18W bulbs that Mercedes supplies these days as I have obtained mine from a local Osram stockist a few years ago.
Maybe others that have ordered from Mercedes can confirm this.
tel76
Re: Light Bulbs
« Reply #2 on: January 28, 2011, 08:47:09 »
Hello Jaco,
If you look at Thelews pictures of his beautiful car you will see what is fitted(i assume these will be correct).
Eric
jacovdw
Re: Light Bulbs
« Reply #3 on: January 28, 2011, 10:48:37 »
Eric,
The 2 clips on John's pagoda are the same clips that I was referring to...  ;)
