Author Topic: back seat compartment covering--vinyl or carpet??  (Read 8346 times)
rmmchl
  • USA, WV, Charleston
« on: January 28, 2011, 02:55:11 »
did the early 250sl's come with carpet or vinyl on the back seat area where the soft top compartment release handle is????? Gahh sells the vinyl or leathwer for this area. Mine is carpeted
michael romeo
1967  250sl
signal red
  • USA, WI, Mequon
Re: back seat compartment covering--vinyl or carpet??
« Reply #1 on: January 28, 2011, 03:01:10 »
Not sure whatcher talkin' about Willis...
« Last Edit: February 27, 2011, 17:54:49 by thelews »
« Reply #2 on: January 28, 2011, 04:22:41 »
I have a 230 but mine is mb-tex in that area. The carpet runs along the back... Just so you know it does exist.
  • USA, WI, Mequon
« Reply #3 on: January 28, 2011, 13:13:59 »
I'll double check mine tonight.
  • USA, WI, Mequon
« Reply #4 on: January 28, 2011, 22:43:01 »
Not losing my mind...
I'd like to see a pic of the area with vinyl and how they did that.
« Last Edit: February 27, 2011, 17:54:17 by thelews »
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #5 on: January 28, 2011, 22:48:50 »
My 66 230 is like John's.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
bogeyman
  • USA, NE, Omaha
« Reply #6 on: January 28, 2011, 23:45:34 »
They might be referring to 107s.  They have vinyl in that area.  I think all 113s have a single piece of carpet that covers the bulkhead area up to the front corners by the doors.
Rick Bogart
1969 280SL Silver(180)/Green
1993 500E
1972 350SL
1995 E320 Cabrio
« Reply #7 on: January 29, 2011, 04:22:46 »
This is the original vinyl on my early 230SL. The carpet is replacement square weave from Miller's in 1997 -- (and very dirty now that I look closely!) The center piece came with the set and was preformed to fit as you see it.
menesesjesse
  • USA, MD, Indian Head
« Reply #8 on: January 29, 2011, 04:34:02 »
I have a 1966 230SL and these peices were leather and original as the numbers on the back of the leather were still written.  I also had a 1967 early car that had black leather on those pieces.   Hope this helps
Jesse
1966 Mercedes 230 SL auto
2003 Mercedes E500
1992 Ford F150
1994 Ford Bronco
2019 Shelby GT350R
1967 Mercury Cougar XR7
jacovdw
« Reply #9 on: January 29, 2011, 12:17:24 »
Not entirely correct.
There are two distinct samples as seen in the photos James Huber and John (thelews) posted.
The earlier cars have a vinyl/leather (depending on interior options) panel as James's car and that the chassis number cut-off is up to 042 004963.
From chassis number 042 004964 onwards, it resembles John's car where the panel is smaller and the area under the release lever is carpeted.
  • USA, WI, Mequon
« Reply #10 on: January 29, 2011, 15:07:06 »
But, the REAL question is....
whose release handle is pointing in the correct direction?  I'm not sure if mine has ever been off.
jacovdw
« Reply #11 on: January 29, 2011, 15:28:25 »
Yours is correct John...  ;)
The release handle should point downwards.
I guess James has some explaining to do...   ;D
« Reply #12 on: January 29, 2011, 16:37:39 »
Well, not sure why I am upside down. I don't believe I have ever had that lever off. On the flip-side,  ;) it seems easier to use my way... Is it complicated to turn around?
« Last Edit: January 30, 2011, 02:19:21 by J. Huber »
jacovdw
« Reply #13 on: February 02, 2011, 11:21:31 »
James,
It should not be that difficult to turn the lever around.
If you look inside the soft-top compartment, you would see a 8mm bolt that needs to be undone to allow the lever to slide out.
Just note the correct orientation of the relevant parts and flip the lever 180° and reassemble.
While you are at it, you may also consider a good clean and lube...
« Reply #14 on: February 02, 2011, 20:33:24 »
(Fully support Jaco's explanations here.
Just my 2 cents ...
Achim)
