Please check out joining the
Emergency Contact List
for help during your travels!
Body, interior, paint, chrome, and cosmetic items
original carpet underlayment material
Topic: original carpet underlayment material (Read 4156 times)
rmmchl
Full Member
Silver
USA, WV, Charleston
January 29, 2011, 00:26:12 »
my 250sl has that black , thick, hard, material glued to the metal floor pans under the carpet. Some of it has peeled off over the years. and I would like to replace all of it. Do they still make this stuff?? what was it??? how do you get it off???
michael romeo
1967 250sl
signal red
Full Member
Platinum
USA, OH, Blacklick
Re: original carpet underlayment material
January 29, 2011, 03:39:39 »
You used to be able to buy it in rolls from the dealer. The same material was used in sedans of the era. There are many similar domestic sound deadening materials on the market.
Heat is the best way to remove it. A good heavy duty industrial heat gun and a scraper will work.
Raymond
Full Member
Platinum
USA, FL, Jacksonville
Reply #2 on:
January 29, 2011, 19:33:43 »
Which raises a question for me. I am considering installing Dynamat under the carpet when I replace it. I'm sure it will be a bear to remove some years down the road. I guess I can adopt the attitude that will be someone else's problem.
Has anyone done this more than a couple of years ago, and is there anything that you wish you had done at the time of installation.?
badali
Full Member
Platinum
USA, Pa, Butler
1966 230SL
Reply #3 on:
January 29, 2011, 23:32:24 »
Check with an upholstery shop. They may have a similar material to the original. Here is the untouched matting in my car.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
Rolf
Reply #4 on:
January 30, 2011, 10:07:05 »
You can use Dynamat or Fat Mat. Then cover it with jute. I used Dynamat with jute under the carpet and it's fine. You can get that at a stereo store. Bud's Benz uses that when they restore a car and was recommended to me by Brad. He said you can get it at an auto stereo store.
