Author Topic: 230 SL Wire Diagram  (Read 5949 times)
healey100
230 SL Wire Diagram
« on: February 11, 2011, 22:51:28 »
Hi, I am having troubles with the cold start engine, at the Technical manual shows the diagram wiht the time switch but the part number 33 doesn´t have any name, what is that?
I am having troubles too when the car reach the operation temperature and I stop in a red light the car, the revolutions goes to 0 and the car stops.
If somebody want to send a picture or a diagram you can use my email address too topping@industriasodi.com thank you all-
Re: 230 SL Wire Diagram
« Reply #1 on: February 12, 2011, 07:25:27 »
The legend to the wiring diagrams and number identification is located here:
http://www.sl113.org/wiki/Electrical/WiringDiagram
« Reply #2 on: February 12, 2011, 13:44:07 »
Hello Healy,
On the engine stopping, and cold starting..... make sure that the main fuel filter is not dirty. All other tune-up items like timing, dwell, spark plug wires, and spark plugs should be checked.  Next you may try to adjust the air screw on the intake up a bit to get the engine to idle a little faster. The fuel mixture screw on the back of the injection pump can also be adjusted if more fuel is needed. There is lots of information on these items here. Ask specific questions if you need to.
For the cold start use a 12 volt test light or voltmeter to check to see if the intake cold start vavle (CSV) is being activated during cold starts.  Also check to see if the cold start solenoid on the injection pump is activated anytime the starter is activated. Keep us up to date.
« Last Edit: February 12, 2011, 15:38:33 by ja17 »
healey100
« Reply #3 on: February 12, 2011, 14:38:03 »
Thank you very much, I will try today and I will let you know on monday.
Reards
