Please check out joining the
Emergency Contact List
for help during your travels!
General Discussion
Need help identifing part?
Topic: Need help identifing part? (Read 3142 times)
steves sl
Associate Member
Regular
USA, WI, CEDARBURG
February 17, 2011, 03:13:48 »
I picked some parts from the platter (yellow zinc) on Monday and this part was in the box. I don't remember, what it's for, or if I picked up someone elses part.
S. Schlaefer
jacovdw
Re: Need help identifing part?
February 17, 2011, 09:04:07 »
That is a clamping plate that is bolted to the bracket on the inner fender where the front brake flex hose and the metal brake line are joined.
The serrated ring prevent the flex hose from rotating. On the bracket mounted on the inner front fender should be a caged nut to receive the bolt that fixes this plate to the bracket. These plates are only used on the front flex hose to metal line joints.
Hope this helps.
steves sl
Associate Member
Regular
USA, WI, CEDARBURG
Reply #2 on:
February 18, 2011, 02:43:18 »
Thanks,that's exactly what it is. I must of had a senior moment (failing memory).
S. Schlaefer
General Discussion
