Author Topic: Need help identifing part?  (Read 2715 times)
steves sl
  • USA, WI, CEDARBURG
« on: February 17, 2011, 03:13:48 »
I picked some parts from the platter (yellow zinc) on Monday and this part was in the box. I don't remember, what it's for, or if I picked up someone elses part.
S. Schlaefer
jacovdw
Re: Need help identifing part?
« Reply #1 on: February 17, 2011, 09:04:07 »
That is a clamping plate that is bolted to the bracket on the inner fender where the front brake flex hose and the metal brake line are joined.
The serrated ring prevent the flex hose from rotating. On the bracket mounted on the inner front fender should be a caged nut to receive the bolt that fixes this plate to the bracket. These plates are only used on the front flex hose to metal line joints.
Hope this helps.
steves sl
« Reply #2 on: February 18, 2011, 02:43:18 »
Thanks,that's exactly what it is. I must of had a senior moment (failing memory).
S. Schlaefer
